Post by captjim on Apr 27, 2022 4:33:57 GMT
I noticed unusual color texture (not brown) is saildrive gear oil. (88 hours on oil). Of course I am changing the oil, however I also got it tested to try to understand the issue.
Test showed:
1. higher than normal viscosity 2. higher that normal insolubles (oxidized solids). 3. Aluminum, iron, and copper read high compared to averages.
Has anyone experienced these results and if so what what the diagnosis?
thx!
Post by Don Reaves on Apr 27, 2022 11:04:47 GMT
I'm hoping this is a stupid question, but did you inform the test company that this was gear oil, not normal lubricating oil?
Post by NZL50505 on Apr 27, 2022 20:22:56 GMT
Which model saildrive and what oil are you using?
Reason for asking is certain oils (even ‘approved’ specs) can contribute towards problems in certain drives.
Post by captjim on Apr 30, 2022 1:36:23 GMT
thank you. it is SD50-t model. and I am using Quicksilver 90 High Performance Gear Lube. API GL 4.
thx Jim
Post by captjim on Apr 30, 2022 1:37:41 GMT
Yes, i let them know the oil type. thx Jim
Post by NZL50505 on Apr 30, 2022 22:38:20 GMT
thank you. it is SD50-t model. and I am using Quicksilver 90 High Performance Gear Lube. API GL 4. thx Jim Ok that’s the right oil for that SD. Have you noticed any clutch slippage when engaging forward?
Post by captjim on May 3, 2022 15:08:40 GMT
No i have not. Jim
