Post by no3l on Apr 18, 2022 23:38:09 GMT
Hi
I have. noticed traces of corrosion on the P-bracket of Rhiannon (SO36i, 2008) when commissioning this year.
From new there hasn’t been an earth strap on the bracket, is this standard for Jeanneau?
The bracket is fully encased on the inside of the hull so I can’t fit a stra, would a galvanic isolator help?
I would appreciate any suggestions.
Thanks Noel
Post by Charlie-Bravo on Apr 19, 2022 7:49:44 GMT
Odd that it has only been noticed recently ....
You have probably already read the posts here about the braided cable that a lot of Jenneau boats have, that corrode away, and are usually covered in gel coat and glass fibre at the bracket bolting, perhaps yours just got buried....... and is hiding in the gel coat.
It would seem a worth while and necessary task to dig out one P bracket bolt and add a cable to stop the corrosion.
Some folk here have added an anode to the P bracket, but not being connected up to the ground circuit , I wonder if it has worked , it might slowdown the corrosion bit.
Yout could bolt a strip of brass / copper from the bracket to the hull anode, but it's not a tidy solution, adding the internal cable is going to be much neater and last a lot longer.
Multitool and hoover recommend
Post by no3l on Apr 20, 2022 17:25:21 GMT
Thanks CB,
Yes it only showed up this year, we take the boat out every winter and this is the first time it has occurred. Nothing has changed on the boat so I'm not sure if it is anything to do with the connections in the marina.
We don't use shore power.
The only thing that may have any significance is our new neighbour in the marina is a steel hulled motor boat. But my understanding of galvanic corrosion is that it needs an earth connection but as we are not using shore power this connection is not (should not be) the issue and I cannot see a galvanic isolator being of any use in these circumstances but an anode on the P-bracket may help.
Questions for other SO36i owners: Is there an earth cable on the P-bracket that I am missing? Has any one retro fitted one?
Thanks Noel
Post by no3l on Apr 20, 2022 18:34:50 GMT
Hi,
Sorry to be a pain on this topic.
On page F11/1 of the schematic diagram an earth connection is shown for the P-bracket.
Does anyone know if this is buried in the glassfibre and connected to earth elsewhere in the boat because I cannot find any cable in the area of the bracket.
Thanks again Noel
Post by Charlie-Bravo on Apr 20, 2022 19:39:09 GMT
If you are still out of the water, a simple resistance test with a multimeter from your P bracket to either the hull anode or prop shaft will determine if such a hidden cable exists, doesn't have to be an expensive instrument, it just needs to show a connection or not.
Post by Trevor on Apr 21, 2022 0:25:04 GMT
Post by no3l on Apr 21, 2022 9:31:02 GMT
Hi Trevor,
Thanks very much for that link, I missed that thread. It's very useful.
I'll be checking the boat over the week and and will update on how I get on.
Thanks again Noel
Post by no3l on Apr 27, 2022 9:07:44 GMT
Hi,
The story continues.
I checked the continuity between the P-bracket and earth and there is no connection.
I emptied the aft cabins and still couldn't see any sign of an earth strap for the P-bracket and there is no sign of a corroded cable. In fact the housing for the bracket is clear so it looks as the earth strap was never fitted.
I had to launch so I've put an anode on the bracket as per previous threads so hopefully that will help protect the bracket while I figure out how to fit an earth strap.
Regards Noel
Post by Trevor on Apr 27, 2022 10:43:27 GMT
Hello Noel,
That is very interesting that you can see no sign of an earth strap. I think the anode you have fitted will provide the required protection.
Trevor.
Post by Trevor on Apr 27, 2022 10:43:30 GMT
Hello Noel,
Trevor.
