ted415
Post by ted415 on Apr 7, 2022 0:21:54 GMT
ted415
Post by ted415 on Apr 7, 2022 2:21:57 GMT
He also said this.....
"You would need to measure the area where your existing pump is and make sure this fits. You also have to tee off from the sink cold water line to the electric valve. Also have to run 12 volt power wire. Usually from the main fuse box feed behind dash"
