Post by panoramix on Jan 9, 2020 9:37:38 GMT
My so37 is in Greece and i want to order a new cutlass bearing to bring it with me this spring. i know it is full rubber. Anybody knows the various sizes?
Shaft or inner diameter is 25 mm
The next sizes are available from the shop:
Outer diameter 34, 36 or 40 mm? Lenght 55, 70 or 100 mm ?
Post by MickeyB on Jan 9, 2020 13:51:58 GMT
My 34.2 is 35mm so may be the same but not too sure.
However, just to mention that the length is NOT that important. If you can get the same, then great, but a longer one always fits (bar perhaps the grub screw points which is a minor niggle). Just leave it poking out or shorten it - your choice.
Post by panoramix on Apr 17, 2021 18:37:08 GMT
In case this thread shows up in a search; the size is 36 mm for a SO37 2003.
The length is 83 mm, but it's no problem if it is a litlte longer.
After all the covid-19 I was now able to replace it.
