Post by NZL50505 on Nov 28, 2019 10:51:02 GMT
Owner’s aft cabin whiffs of engine / diesel smell after running engine for a while.
Post by John on Nov 28, 2019 14:27:08 GMT
Owner’s aft cabin whiffs of engine / diesel smell after running engine for a while. Have both vents been checked for any leaks ( Electric blower and standard vent ), we have used a citrus degreaser to clean an diesel from the bilges in the past .
Post by NZL50505 on Nov 29, 2019 3:34:26 GMT
Just did engine service inc full cleanup of compartment and bilges. Used to smell last season after use as well.
Post by timpeacockuk on Nov 29, 2019 16:49:34 GMT
I had a similar issue a few years ago. I traced it to a loose joint on the fuel return pipe on top of the tank under the bed. It had left a small puddle of diesel. A quick ‘adjustment’ with a screwdriver fixed it. Tim Peacock
Post by NZL50505 on Nov 29, 2019 19:20:11 GMT
Thanks good idea will take a look.
Post by mickmeck on Dec 2, 2019 19:23:09 GMT
I also had a smell and accidentally overfilled the fuel tank which leaked out the fill elbow on the tank. Once I fixed that, I never smelled the odor again.
Post by NZL50505 on Dec 3, 2019 8:09:37 GMT
I also had a smell and accidentally overfilled the fuel tank which leaked out the fill elbow on the tank. Once I fixed that, I never smelled the odor again. Where is the fill elbow? How do I locate it and check it for leaks?
Post by pathfinderstu on Dec 16, 2019 15:53:24 GMT
Probably leading from the top of the fuel tank lol...
Post by mickmeck on Dec 16, 2019 16:08:58 GMT
Yes, exactly. In my 43DS the fuel tank is the first floor board that opens up. The fuel fill line is quite visible. Until it was overfilled the opening was extremely small and not noticeable. As I said, I have had no odor since. As a reference I sail/motor between 1600 and 2000 miles in the Chesapeake every season - so it gets a work out.
Post by Syrah on Dec 16, 2019 21:32:14 GMT
In a two berth version of the 42DS, the fuel fill line can be accessed by removing the headrest panel in the main cabin and opening the panel on the Stbd side of the wall behind the headrest. The headrest is attached with Velcro. The panel opens with a push to extend handle.
Post by Trevor on Dec 19, 2019 20:26:46 GMT
Hi NZL8970, We have experienced diesel weeping out of the fuel intake on top of the tank under the starboard side of the aft bed, causing a fuel smell in the aft cabin. In fact, I think we have the same problem now but it is just such a pain to fix I am avoiding it. If the tank is completely full with the fuel filled up the filler tube, the positive pressure on the gasket I think causes them to weep a little. It is very disappointing and in my view, difficult to fix long term. This was my last attempt. jeanneau.proboards.com/thread/6559/fuel-pickups-weeping-attempt-repairRegards, Trevor
Post by Tafika II on Dec 19, 2019 22:42:06 GMT
I had a fuel leak several years ago. Here is the link for my posting. link
Post by jy51 on Dec 20, 2019 10:41:22 GMT
Owner’s aft cabin whiffs of engine / diesel smell after running engine for a while. Maybe not very helpful, but while on the subject of diesel smells, our mechanic has a special aerosol which he sprays all over the engine and engine bay after he has carried out an oil change, some kind of anti-diesel air freshener. I have never seen it advertised before but it must be out there somewhere!
Post by alenka on Dec 29, 2019 16:47:54 GMT
