Post by vasko on Nov 10, 2019 10:10:31 GMT
fed up with VP crazy prices - sealing rings x15 price from normal one here are the sizes for the one that you change most frequently : Gearbox(MS2B etc) : Sealing ring 873100 size : 40x68x12 Sealing ring 873094 size : 22.5x53x10 Sealing ring 853868 size : 25x35x7 Engine ( 2003 etc.) Sealing ring 40005775 size: 80x100x10 Can be sourced from : www.123bearing.co.uk/ ( I use the upper quality ones with double lips - last a lot longer the original from VP shop)
Post by ianqv on Nov 28, 2019 12:29:45 GMT
Cheers Vasko
