robertf
Jeanneau Model: 2009 42 DS
Yacht Name: Special Forces
Home Port: Georgetown, Maryland
Country: United States of America
Post by robertf on Sept 28, 2019 13:16:27 GMT
Trying to help friend. 2014 41DS needs to know how to remove the factory installed microwave. Appears to be secured from the bottom. Any help appreciated. Cheers, Robert
Post by whiteswan on Sept 23, 2022 9:14:20 GMT
Robert, l need to replace the microwave on my 41DS, how did your friend get on with his replacement? any tips?
Post by wright1 on Aug 8, 2023 11:15:37 GMT
Hi You must first remove the surround which is held in place by two screws on each side inside the cupboards . The microwave is fix the plywood base . To remove the microwave and base together you have to remove the screws inside the cupboards That hold the base. Open the door and lift up and out wards
Post by Zanshin on Aug 8, 2023 13:02:18 GMT
It is important to measure the dimensions - my microwave broke and I haven't found a replacement that will fit.
Post by whiteswan on Aug 8, 2023 15:00:21 GMT
Hi You must first remove the surround which is held in place by two screws on each side inside the cupboards . The microwave is fix the plywood base . To remove the microwave and base together you have to remove the screws inside the cupboards That hold the base. Open the door and lift up and out wards Thanks for the update.
Post by Trevor on Aug 9, 2023 7:30:02 GMT
Hello robertf,
Replacing the microwave seems like a very simple task but somehow I managed to take that once in a decade opportunity and ruined the outcome by overthinking it. I found a microwave that was called an inverter Microwave. I thought, great, I can set the power to low and then instead of hammering my batteries too hard I can wind back the power and take it easy.
Great in theory. In practice its hard to set the power on the microwave. I'm more of a "press here for one minute" man so we just use the thing at full whack. it draws about 180 amps from the poor old hosue batteries so my attempt to be gentle on them failed. Also, the door on this microwave is the full width of the device. Looked great in the shop and I thought it was a great design. In practice however, the bigger door opens over more of the gas burners so once again, I snatched defeat from the jaws of victory.
I couldn't have chosen a worse mnicrowave oven for a boat. I paid too much for a great device that simply doesn't suit my needs. My advice is choose one of those really simple, very inexpensive ones. And yes, removing and installing it was not particulary easy.
