Post by bikerwookie on Sept 26, 2019 12:10:46 GMT
I see the 33i has a deck light in the diagrams but I do not have one.
Does anybody know if the wiring goes up to the steaming light and is just blanked off? If not where do the wires exit?
Post by johannes on Sept 26, 2019 12:29:44 GMT
You can easily check: look where the cables from the mast are connected behind a ceiling panel under the deck. Find the cable for the steaming light (check with a multimeter if it is not obvious). If there are three wires in the cable, one of them should be for the deck light. If there are only two, it's for the steaming light only.
Post by bikerwookie on Sept 26, 2019 13:23:13 GMT
The cable for the deck light goes into the mast I just can’t find where it exits. Was hoping to save a trip up to take the steaming light off.
Post by zaphod on Sept 26, 2019 20:06:30 GMT
My guess is that if the wiring is there it is the same cable that supplies the steaming light, intended for a combination steaming/foredeck light fixture.
