Post by gre2 on Sept 18, 2019 20:54:42 GMT
I need to rebed the bow pulpit on our 2001 Sun Odyssey 37 Is it accessible from the V berth through the windlass inspection plate? Any suggestions welcome.
Post by panoramix on Sept 18, 2019 21:27:38 GMT
It is accessible from the anchorlocker. There is a round plastic cover that can be removed.
These plastic covers are also well known for water leaks in the front cabin.
Post by gre2 on Sept 21, 2019 16:00:12 GMT
Thanks for your help, will check that cover next time I'm up to the boat.
Post by gre2 on Oct 21, 2019 20:40:48 GMT
Checked the cover plates in the anchor locker and they are not leaking. So I think the aft post of the port bow pulpit is leaking. Has anyone experience in re-bedding it.
Post by johannes on Oct 22, 2019 16:35:44 GMT
There can also be a leak around the anchor locker drain.
Post by gre2 on Dec 13, 2019 0:49:35 GMT
Can anyone tell me if the bow pulpit on the SO 37 is through bolted. I assume there is access to the underside of the deck through the V berth.
Post by Bora on Dec 13, 2019 2:59:36 GMT
If i remember right you access the aft ones from the cabin and the forward ones by removing the wooden panel at the top of the V-berth.
The friend I sold her to ended up doing it over the winter and it was simple enough. Use butyl tape rather than sika as is doesn't go off so will allow a bit of flex.
Post by gre2 on Dec 19, 2019 15:27:14 GMT
Any chance you could contact the person who bought your boat or give me their email address if they don't mind.
Thanks
Post by Bora on Dec 19, 2019 15:55:31 GMT
I’ll give him a shout.
