jos
Post by jos on Sept 11, 2019 15:47:15 GMT
There appears to be a leak in the hot water tank and I was wondering where it is located. I think it must be under the aft berth, but have not found it yet. My boat came with the large single aft berth and the forward V-berth. I'd appreciate any direction from anyone in the know. Thanks.
Post by pdodds on Sept 12, 2019 12:09:49 GMT
The hot water tank is accessible thru an access panel in the stern port side corner of the aft berth. It’s a 6gallon tank. The access panel is vinyl wrapped and held on with Velcro. You can also see the top of the tank from the port lazarette if you look down to the left of the propane tank compartment. All the tank connections are accessible thru the aft berth.
jos
Post by jos on Sept 12, 2019 16:14:51 GMT
Thanks a lot. I'll check it out tomorrow.
jos
Post by jos on Sept 27, 2019 15:49:52 GMT
jos
Post by jos on Sept 27, 2019 15:51:27 GMT
'Poor Richard'
Good information. Found the panel and the heater and replaced. Thanks for your assistance.
JOS
Post by pdodds on Sept 28, 2019 11:32:17 GMT
'Poor Richard' Good information. Found the panel and the heater and replaced. Thanks for your assistance. JOS Feel free to pick my brain if you have anymore questions. Glad it worked out.
jos
Post by jos on Nov 8, 2019 15:19:49 GMT
jos
Post by jos on Nov 8, 2019 15:33:57 GMT
I installed the hot water tank and attached the water line from the engine that is designed to supply heat to the water in the tank to heat it.
With the engine running, the hose entering the tank feels warm to the touch, however even after two hours of motoring, the hot water at the sink is only tepid!
Any ideas as to what the problem might be? I used the same hose setup off the old tank, which provided very hot water before it began to leak.
could there be a air lock somewhere? WAter reservoir for the coolant is at the midline on the overflow tank. seems like only changing the tank shouldn’t be so drastic in the water temperature.
JOS
