Post by vasko on Sept 2, 2019 7:57:00 GMT
Post by johannes on Sept 2, 2019 12:25:18 GMT
But is is not really "in one", is it? It is just both sold as a package. Marelon is one of two leading brands in plastic through hulls and seacocks, the other being Tru Design. A few years ago Marelon had some bad press following quality issues (failures), but that might have improved.
Post by vasko on Sept 2, 2019 18:16:51 GMT
But is is not really "in one", is it? It is just both sold as a package. Marelon is one of two leading brands in plastic through hulls and seacocks, the other being Tru Design. A few years ago Marelon had some bad press following quality issues (failures), but that might have improved. It seems that the truhull directly bolts on the tap - and the tap is laying on the hull e.g not separate parts but one design thing - e.g taking less space (I have issue with spaces around my truhulls)
Post by ianpowolny on Sept 2, 2019 18:58:49 GMT
Vasco,
Have you looked at the cost difference usin TruDesign. From svb24.com a 1/2” valve is €48 and a thro hull is €10. I can measure up our 1/2 inch valves if that would help.
Also I couldn’t find out which Certifying Authority certified the Marelon valves.
Ian
Post by johannes on Sept 3, 2019 7:51:54 GMT
I don't think Tru Design is a good option if space is an issue. The Tru Design seacocks are larger than normal brass seacocks.
Post by Caxton on Sept 3, 2019 18:36:25 GMT
