Post by jalexand on Aug 16, 2019 16:30:13 GMT
Can anyone with an early 2000’s DS43 be willing to send me pictures of how their Vang is configured. I think mine is misconfigured and I’m trying to figure out how the lines are setup.
Thanks, Jason
Post by zaphod on Aug 16, 2019 17:13:49 GMT
Why don't you post pics of your vang? There is more than one "right" way to set up a vang...
Post by jalexand on Aug 17, 2019 15:40:05 GMT
Post by jalexand on Aug 17, 2019 15:41:22 GMT
The challenge is that the two blocks at the base of the vang are together. They can’t pull the Vang down.
Post by jalexand on Aug 17, 2019 22:12:03 GMT
I finally found a name and found the rigging instructions. It’s functional again as a test sail shows today.
Post by rene460 on Aug 18, 2019 8:48:55 GMT
Hi Jalexand,
Glad you found the instructions and have it sorted. It is definitely not right in the pictures, but a different manufacturer to mine so was not easy to see what should be done. Perhaps a picture of how it is now would be of interest to all.
Post by zaphod on Aug 20, 2019 0:19:54 GMT
Yes, it is definitely wrong in the pic. It should be a cascade purchase. The line that goes through the sheave at the top of the vang should not be tied back on itself. One end should be attached to the lower floating block, and the other end should go through the top sheave and back down to terminate somewhere at the bottom of the vang. On my vang the termination is done inside the vang, so it is possible yours was originally like that as well. Perhaps it broke so someone just tied it off. The rope that comes from the cockpit goes through the turning block at the base of the mast, up through the floating block and back down to terminate at the base of the mast on the other side of the vang. (Unless you want to have vang control on both sides in which case you go through another turning block and back to the port side cockpit.)
Unfortunately I cant find a pic of my boat that shows the vang clearly.
Post by johannes on Aug 20, 2019 6:43:20 GMT
Here's a picture of ours, although a different brand of rigid vang. The cascade wire goes inside the vang to a sheave at the top. The block and tackle arrangement can have different purchase depending on the need. We only have 3:1, but we tension it with the halyard winch so it's OK. www.23hq.com/Johannes_s/photo/58861151/original
Post by zaphod on Aug 20, 2019 14:46:14 GMT
Here's a picture of ours, although a different brand of rigid vang. The cascade wire goes inside the vang to a sheave at the top. The block and tackle arrangement can have different purchase depending on the need. We only have 3:1, but we tension it with the halyard winch so it's OK. www.23hq.com/Johannes_s/photo/58861151/originalYes, that is the same as mine, except we only have 2:1 pulling on the cascade for a total of 4:1. I'm sure I will upgrade the purchase on my vang at some point. That is one thing that really annoys me about my boat...everything, even the vang and traveller are winch-dependent in any but the lightest winds!
