Post by Trevor on Jun 21, 2019 11:54:22 GMT
I recently replaced an Aqua Signal 41 series light on the stern on our SO42DS. After wiring the light it didn't work. The incandescent bulb is now replaced with a LED. The problem is the LED is incompatible with the housing. I mention this because it is a bit unusual to have a light delivered from the supplier that does not work because the bulb is incompatible with the housing. I modified the housing slightly to allow for the issue. Hard to believe a high quality light can be supplied that simply doesn't work! This may help someone who has the same problem. Regards, Trevor Light replaced on stern of sapphire www.23hq.com/yachtbird/photo/56272822/originalLED Bulb requires voltage between either terminal and case rather than between the two base terminals www.23hq.com/yachtbird/photo/56273166/originalThe negative terminal had to be connected to metal housing ( red wire, green heatshrink) www.23hq.com/yachtbird/photo/56273209/originalTop View www.23hq.com/yachtbird/photo/56273237/original
Post by Tafika II on Jun 21, 2019 19:31:25 GMT
Hi Trvor! How's life treating you? Our stern light failed due to a leak. Tried fixing it and installing a LED lamp like you did. It failed and leaked again. We replaced it with Hella marine NaviLED Stern Navigation Light 980520511, but this time I mounted on on a flat plate on the aft side of the SS arch for better visibility. Filled the old holes with colored gelcoat.
Post by Trevor on Jun 22, 2019 12:51:55 GMT
Hi Brent,
All good here and I hope you are doing well. We are back on the boat for a few of months and just getting some maintenance work done. I probably should have put the light on the arch but took the easy way out.
