Post by CaptSteveZ on Jun 13, 2019 18:55:25 GMT
Post by MickeyB on Jun 14, 2019 6:31:11 GMT
Hey! I was (heaven forbid!) going to fit a pair of these to my sailing boats transom.
Can I ask did you do them yourself? Were they hard to do if yes, and which ones are they?
Finally, power consumption please?
Many thanks.
Mike
Post by vasko on Jun 14, 2019 17:04:36 GMT
I’m thinking about led stripe inside the hull - the light should be able to penetrate to outside in the water
Post by CaptSteveZ on Jun 14, 2019 19:48:54 GMT
These are OceanLED series X4. The marina installed them. A bit more complicated because have to drill into the stern of the boat.
Deleted
Deleted Member
Post by Deleted on Oct 13, 2020 12:32:46 GMT
I am intending to buy OceanLED X4, Is it good?
Post by andreww on Nov 24, 2020 13:52:31 GMT
Same question. i also want to change the underwater lights for my boat but i am unable to choose a good one yet.
nigelnc11
Jeanneau Model: NC11
Home Port: Blairgowrie, Port Phillip Bay, Victoria
Post by nigelnc11 on Nov 26, 2020 11:03:11 GMT
Macris are very good. Small hole for wire is all that needed. Wide spread.
switch
Post by switch on Dec 22, 2020 18:10:02 GMT
I’ve done a bit of research on underwater lights. I kept coming back to one brand - Lumishore. I’ve just ordered some SMX 53’s. They are more expensive but you get what you pay for.
Deleted
Deleted Member
Post by Deleted on Jan 17, 2021 8:29:36 GMT
Recently I bought Lumitec SeaBlaze3, very very satisfied with them. There are two things that I really like about this light is that it is dimmable and it is really easy to install.
