Post by Bora on May 18, 2019 15:54:45 GMT
Just waiting for my new liferaft to arrive, has anyone taken the deckhead panels down? I’m going to mount it forward of the spray hood.
Post by Tafika II on May 18, 2019 16:39:06 GMT
We mounted our in the position you indicated. It's a Viking offshore 4 person raft. Forward bolts are straight through the cabin top and after have a nylon spacer betwen the cabin top false cover and the cabin top. Sealed all with silicon pads with washer and locknuts inside the celing liner. Very easy job except the spacers alignment.
Post by Bora on May 18, 2019 16:41:18 GMT
Brilliant. I think a much better location with a HRU rather than in the locker.
Post by Bora on May 22, 2019 20:23:23 GMT
Does anyone know if I’ll be able to drill right through the deck? It looks like this whole area is removable, the main track isn’t attached to it.
Post by Evening Star on May 22, 2019 23:02:54 GMT
Be careful that you don’t impede your companion way hatch cover as it slides forward with the raft bolts. The hatch uses a lot of that space.
Post by Bora on Jun 3, 2019 11:51:56 GMT
We mounted our in the position you indicated. It's a Viking offshore 4 person raft. Forward bolts are straight through the cabin top and after have a nylon spacer betwen the cabin top false cover and the cabin top. Sealed all with silicon pads with washer and locknuts inside the celing liner. Very easy job except the spacers alignment. Did you have to remove the false cover first? Is it just secured with the forward bolts?
Post by Tafika II on Jun 3, 2019 18:46:59 GMT
We remove the false cover and bolted fore and aft (4 locations). Resealed all of the screws and the gaps on the false cover. Fabricated nylon spacers between the false cover and the cabin top to prevent sag. Also place silicon sheet cut-to-size pads between the raft cradle and the cabin top & false cover.
Post by Bora on Jun 3, 2019 18:49:35 GMT
How did you get the false cover off? I’ve asked my jeanneau dealer but no response as yet.
Post by Tafika II on Jun 3, 2019 19:09:29 GMT
Ours has several sc news, then cut the caulking in the joints. Not difficult but you have to take your time so you don't cut into the gelcoat. After removal, you have to remove all of the old caulk. I'm sorry I didn't take a ny pictures on this project that I can share
Post by Bora on Jun 3, 2019 19:16:37 GMT
To access the screws did you have to go from underneath?
Did the main track get in the way at all?
Post by Tafika II on Jun 10, 2019 16:48:46 GMT
Sorry for the late reply. Our screws are on the outside and yes, the traveler had to be removed as the panel goes underneath. No a hard task, jus remember to recall everything.
