Post by uli057 on May 16, 2019 7:42:42 GMT
Hi owners... Here are the next things to do. Fittings are all swapped and made in bronze. Hull and keel connection repair. The hull already has Geelshield body Antifouling comes new. The wooden rudder blade must be repaired. The Liberty develops to a large construction site, because also still windows must be repaired as well as the shaft bearings inside and outside. regards uli www.23hq.com/uli057/photo/54903939www.23hq.com/uli057/photo/54903937www.23hq.com/uli057/photo/54903928sorry for the picture link, the image insert has no function on tablet !
Post by sitara on May 16, 2019 22:11:26 GMT
What a great area to work on a boat!
Post by uli057 on May 17, 2019 7:08:32 GMT
Hi, what do you mean by the Area? At Hall the light bad, every time work with light. Outside i see all errors at ship....and ...my taint was after 4 weeks dark brown ...for no cash. thats nothing for the winter time wishes uli
Post by Trevor on May 17, 2019 13:02:32 GMT
Nice work Uli, Big job but it will be great when she's back int he water....
Post by vasko on May 18, 2019 19:30:23 GMT
Uli,
The rudder on my SunLiberty 34 is VERY different shape and from wood(teack I guess).,,
Just about to get my boat in the water finally after 3 weeks working on her 10-12h a day ...
Post by vasko on May 19, 2019 6:03:26 GMT
Post by uli057 on May 19, 2019 10:15:28 GMT
hi all. Thx to Malcom for correted pictures! Vasko. My previous owner already had the rudder replaced once, I saw from the bill... apparently a big problem at jaennaeu. Here in the harbour is another jaennaeu with a rotten rudder! Mine is made of multiplex wood with a cover of glass fibre fleece. But the glued front seam was about to open, I was able to repair this early now. The effect of my rudder is very good, even when resetting. I probably won't get into the water until June, you have to consider that the ship hasn't really been on land since 2006, only a short check every three years. But this time it was urgently due. The Cockpitpersenning is now also due, wanted to make it in dark grey. What are your experiences from the pollution with the individual colors? The Fittings are complete new insert at Bronce.... what a coast ... In Front the WC is gone... there is at next year only a shower bath, but there must i insert at door a white shape plate for resist at water. Pictures for the rebuilt shower bath in front comes later. regards uli
Post by MalcolmP on May 19, 2019 10:32:43 GMT
hi all. Thx to Malcom for correted pictures! Not a problem Uli - they just need to have /original added to the end of the photo url link and they will then load up if you use the insert image icon
Post by vasko on May 19, 2019 19:51:36 GMT
hi all. Thx to Malcom for correted pictures! Vasko. My previous owner already had the rudder replaced once, I saw from the bill... apparently a big problem at jaennaeu. Here in the harbour is another jaennaeu with a rotten rudder! Mine is made of multiplex wood with a cover of glass fibre fleece. But the glued front seam was about to open, I was able to repair this early now. The effect of my rudder is very good, even when resetting. I probably won't get into the water until June, you have to consider that the ship hasn't really been on land since 2006, only a short check every three years. But this time it was urgently due. The Cockpitpersenning is now also due, wanted to make it in dark grey. What are your experiences from the pollution with the individual colors? The Fittings are complete new insert at Bronce.... what a coast ... In Front the WC is gone... there is at next year only a shower bath, but there must i insert at door a white shape plate for resist at water. Pictures for the rebuilt shower bath in front comes later. regards uli You mean the teack plate on tbe seats and the floor ? Or something else in the cockpit ? My one is in pretty original condition all is working and how it should be from tbe factory .... polished the boat for this season and changed the decals now all look pristine again
Post by uli057 on May 20, 2019 6:45:38 GMT
Hi Vasko. No ,all at Cockpit is in good condition allso the teak plates... The Rudder is not at teack rebuilt, it was Multiplex wood. At Germany has this multilayer wood the name " multiplex" it was waterresist, but it was not so good as teak. You see that my rudder another shape is. regards uli
