Post by sailbleu on May 15, 2019 8:23:46 GMT
I guess most of us have had our rudder make that sound , especially when sailing in cold waters , because it is my experience that warm and cold have an effect on the sound a rudder makes . I crossed the golf of Biscay 3 times from North-sea channel to the Mediterranean and back and each had the squeaking/creaking sound at the start of the journey going down and at the end of it going up . The warmer South European & Med-water always had a therapeutic effect . So for me it’s temperature related . But the sound has an more disturbing connotation to it , a bearing that sighs is eventually a bearing that dies . Again , most of us know that greasing the rudder stock makes and end to the groaning . However , the stock and top bearing are such a tight fit ( should be) that a lot of the sprayed on lubricant or silicone is lost and doesn’t creep in where it should be . So for several years I’ve been playing with the idea of installing a dam of some sort around the rudder-stock housing so a lubricant , be it oil or anything else stays in there and drips through . A few days ago I addressed the challenge , because a challenge it is to get a precision job done in such small and confined space . I believe I succeeded , but I yet have to test it once we set off for the season . Would like to share some photos to give a solution that obviously worked for me and this kind of boat . The material used us just ordinary pvc glued on with sikaflex . I had to work with two separate parts as it was virtually impossible to get an integrated one piece item in position . Good luck Regards
Post by MalcolmP on May 15, 2019 8:33:12 GMT
Clever indeed, your inventiveness knows no bounds Will be interesting how it works out long term
Post by uli057 on May 16, 2019 7:53:57 GMT
Post by debenbar on May 16, 2019 19:22:03 GMT
The Jeanneau owners manual for my 39ds says that only WD40 should be used to lubricate the rudder bearings. One time I ignored this and routinely applied a silicon based spray to the rudder bearings which were not squeaking, within a day or two the bearings were squeaking due to the nylon (?) swelling, it took several days repeated flooding with WD40 to cure the squeaking.
Post by sailbleu on May 17, 2019 6:45:41 GMT
The Jeanneau owners manual for my 39ds says that only WD40 should be used to lubricate the rudder bearings. One time I ignored this and routinely applied a silicon based spray to the rudder bearings which were not squeaking, within a day or two the bearings were squeaking due to the nylon (?) swelling, it took several days repeated flooding with WD40 to cure the squeaking. This is a real valuable post . In the past I used several sprays ( mostly silicone ) and as many different things to lubricate the bearing because I had no clue what kind of lubricant would be compatible with the material used for the bearing. However , filling the reservoir I have now with WD40 will not be easy to say the least . I had my mind set on a synthetic low viscosity oil that could gradually work it’s way through , I’m sure the rotation of the rudder will allow ‘ the thicker than WD40 ‘ to also get down to the lower bearing . Very curious though on the consumption of lubricant , not sure if it will disappear via the bottom bearing . The bottom bearing being under water all the time , submerged up to a certain level in other words , and the oil/lubricant being lighter than water , it will take an oil column higher than that of the sea water before the oil seeps through the bottom bearing in to the sea . I suppose it wouldn’t harm to also lubricate that bearing , sandy salt water is after all very abrasive . Regards Ps: thanks for the compliment Malcolm , will report further details on the application
Post by uli057 on May 17, 2019 20:43:45 GMT
Hi, WD 40 is nothing for oiling any bearing. wd 40 is a graet liquid for claer all what are dirty. or for clear fresh sikaflex from any material.. . but Not for bearings. i prefer for that bearing only oil for v4a bearings. the bottom Nylon bearing, this nylon bearing in water does not oil for better work. regards ULI
