Post by uli057 on May 13, 2019 7:49:57 GMT
Post by Trevor on May 13, 2019 9:58:40 GMT
Hello uli057,
Last year I thought the engine intake seacock looked a little nasty so while the yacht was out of the water I thought I would bite the bullet and replace it. I purchased the new sea cock and underwent the task of removing the old one. I did remove the old one and fitted the new shiny one. However, I must admit, when I checked the old seacock closely I was surprised just how good the condition was. The ball valve was in very good condition although the outside of the housing looked pretty bad.
Anyway, the job is done now so I feel a bit better.
Post by vasko on May 15, 2019 8:29:46 GMT
I had issue with 2 of my ball valves when preparing the boat for this season - and decided to change them together with the truhulls- after removing I've inspected the condition in details and one of them ( the bigger one 1 1/2 ) was in so-so condition e.g. needed changing but the small one was perfectly good .... e.g. in brief there is no way to judge from outside the actual condition of the metal...
Post by ohana on May 15, 2019 21:43:54 GMT
I replaced the lot during the past winter months, 8 in total. Fitted DZR replacements. Not such a hard job in the end, the only awkward ones were in the stern lazerette locker. Original fittings from 2012 build showed different levels of decay, quite a lot of pink dezincified in 3 of them. None had any indication of what they were made of, so could only assume brass. Really poor that bronze or DZR was not part of the original fit.
Post by achosenman on May 18, 2019 5:26:40 GMT
I changed all of mine last year on a 2005 SO40.3 They were in very good condition considering the age. I changed them since the boat was new to me and they were OEM.
Post by vasko on May 18, 2019 19:14:06 GMT
Btw: uli I was planing to change all my 10 fittind on my SunLiberty 34 with TruDesign ones but they ware nit available when the two taps broke ... and changed with what was availabe here in Nidri/Greece...
Post by vasko on May 18, 2019 19:20:02 GMT
Post by uli057 on May 19, 2019 10:23:05 GMT
hi Vasko, I had insert the new Trudesign at 1,1/2 Zoll and 3/4 Zoll. But not for all, there is not enough room for this big ball Fitting. And... i wonder at Jeannaeu... why are all holes more greater at the fitting self? There are around the fitting more at 5mm ... Bad or not? I dont no...
regards uli
Post by vasko on May 19, 2019 19:58:35 GMT
hi Vasko, I had insert the new Trudesign at 1,1/2 Zoll and 3/4 Zoll. But not for all, there is not enough room for this big ball Fitting. And... i wonder at Jeannaeu... why are all holes more greater at the fitting self? There are around the fitting more at 5mm ... Bad or not? I dont no... regards uli Hmmmm the hols on my Sun Liberty 34 are exact as the fittings... I will suggest if you change them to rebuild the proper hole size - you can use the International Watertite epoxy filler
