Post by maxsydney on May 4, 2019 21:31:33 GMT
I am trying to set the saloon table to a berth and note it appears to require a poll across the front to add support. Does anyone know where this is typically stored on the Sun Odyssey 37?
Post by capnbrian on May 5, 2019 22:25:01 GMT
On my ‘02 SO37 the support I think you are inquiring about appears to be a plywood slat that fits into slots routed out on the face of the salon seats. I have been through every nook and cranny and have not found anything on the boat that will fit there. I don’t know if the previous owner got rid of it or if it never existed. I am going to make one out of plywood.
Post by maxsydney on May 5, 2019 22:28:57 GMT
Interesting- I pictured a poll going from one slat to the other, but you are suggesting two plywood blocks, I guess around 30cm wide proving additional support at each end? Please post a photo when you get this working.
Thanks
Max
Post by johannes on May 6, 2019 11:08:52 GMT
It's a single piece of plywood that stretches across the space between the seats. I can take a picture next time I'm at the boat (Friday).
Post by maxsydney on May 6, 2019 11:23:30 GMT
Thanks - where do you store it?
Post by johannes on May 6, 2019 13:06:25 GMT
Hmmm... Good question! We rarely use it. I think we store it under the mattress in the forward cabin, but I will check on Friday.
Post by Bora on May 7, 2019 9:22:07 GMT
I used to just store it on one of the little side shelf’s in the forward cabin. Doesn’t take up much room.
Post by johannes on May 24, 2019 9:37:06 GMT
Post by maxsydney on May 24, 2019 21:38:42 GMT
Thanks heaps for posting that. Now I know what to look for - although I am pretty sure I would have seen this already. Trouble is it looks a little like an “off cut” so I can see how someone might throw it away!
Post by mischa on Jun 28, 2019 2:21:51 GMT
Post by mischa on Jun 28, 2019 2:36:15 GMT
Hello Johannes, we are having difficulty setting up that saloon table/bed. Can you tell me what those cutouts are for in the support piece? When we remove the table legs & extend the 2 support rods & slide the table support rods into the relevant holes in the bench, it just doesn’t seem to be an acceptable fit. Are we doing something wrong? many Thanks
Post by johannes on Jun 28, 2019 7:18:49 GMT
The cut outs are for the sliding rods (the white "buttons" in the picture). The supporting piece of plywood has to be oriented so it matches the rods. If it does not fit even then, I don't know. Maybe you have to modify the the cut outs a bit?
