dda
Constant Yacht Maintenance
Jeanneau Model: Sun Odyssey 32.2
Yacht Name: Windspiel
Home Port: River Hamble
Post by dda on Mar 11, 2019 20:53:27 GMT
Hi All,
unfortunately, I need to find out the mast manufacturer and I can't get to the yacht at the moment.
many thanks, Drew
Post by johannes on Mar 12, 2019 8:02:22 GMT
Aren't all Jeanneau masts from Z Spars / Z Diffusion?
Post by MalcolmP on Mar 12, 2019 10:18:42 GMT
Aren't all Jeanneau masts from Z Spars / Z Diffusion? Yes I would expect it is a Z spar, but some Jeanneau's were probably also fitted from time to time with Isomat or Francespar. More recent models have Selden as well. The SO32.1 is listed as a Z Spar, but not the SO32.2 here: www.jeanneau-owners.com/Manuals/zsparprofiles.html but that was based on an old list so might only be up to around the mid 1990's
Post by mikebz on Mar 12, 2019 11:58:25 GMT
Our SO32 (not .2, 2003 vintage) has Sparcraft spars. A 32.2 for sale here says the mast is Sparcraft Ocean.
Post by pdodds on Mar 13, 2019 11:07:26 GMT
I have a 1999 36.2 and it also has Z Spar/Diffusion mast
dda
Post by dda on Mar 21, 2019 22:04:42 GMT
Thank you for all the replies. It's done the job for the time being. I'll post what I find out when after I'm able to get to her just for info. cheers Drew
Post by wildfire on Mar 23, 2019 18:43:17 GMT
Just noticed this thread, when I took the mast off 32.2 last year I noted I took a picture of the label in the mast. This states Sparcraft and gives the profile.
Post by alroma on Apr 17, 2019 12:37:00 GMT
Hi, mine SunOdyssey 32.2 from 1999 have a OCEAN mast made by SPARCRAFT. Also it appears as you try to find the car for mainsail under the www.ronstan.com.au/batten/
dda
Post by dda on Apr 25, 2019 11:15:12 GMT
Hi All,
thanks for the replies. Turns out it is a Sparcraft Ocean.
Cheers Drew
philh
Post by philh on Apr 25, 2019 12:43:39 GMT
Anyone installed a longer boom to a 32.2? I want to install a Barton removable main sheet traveler in the cockpit but the rear berth hatch is directly below the end of the boom so if i install in front of the hatch I dont get any benefit as it will be too far forward and will catch the spray hood.
Or- has anyone routed the main sheet from the coach roof to a position near the helm- I have a wheel not tiller arrangement.
Thanks
Post by peachey on Sept 13, 2020 7:26:10 GMT
Anyone installed a longer boom to a 32.2? I want to install a Barton removable main sheet traveler in the cockpit but the rear berth hatch is directly below the end of the boom so if i install in front of the hatch I dont get any benefit as it will be too far forward and will catch the spray hood. Or- has anyone routed the main sheet from the coach roof to a position near the helm- I have a wheel not tiller arrangement. Thanks Hi, sorry for tagging onto an old thread but did you move the main from the coach roof? I have a wheel and like the idea of moving the main traveller to the cockpit (floor if possible). Thanks
