ricardo
Jeanneau Model: Jeanneau 57
Yacht Name: SHINING GIRL
Home Port: Providence, RI
Post by ricardo on Jan 31, 2019 13:56:22 GMT
My Jeanneau 57 has about 20 of these ETA relays. I am in need to replace at least 3. The most problematic is the RT200 which controls various lights. As near as I can tell it's a 24 V latching relay, 4-pin ISO Mini packaging automotive style. It latches closed with a 24V pulse from a momentary switch (either of two switches in this case) and then the next momentary pulse opens it back up to get an on/off without drawing any current through the coil in the on state. It's a cool way to allow multiple switches (in this case nav station and helm) to control the same relay function (e.g. anchor light). These are not made any more and I have been unsuccessful in sourcing the legacy part. I have also been unsuccessful so far in getting a replacement. ETA does manufacture a very nice, nearly pin compatible programmable part, but when I asked a US distributer to quote qty 8, they would only quote qty 100 for $23,000 USD. Clearly that can't happen. I am wondering if anyone else out there has had any success in sourcing this part or a reasonably compatible substitute. Cheers from St. Lucia Ricardo
nieamm
Cruising Scandinavia
Jeanneau Model: 57
Yacht Name: Liberty
Home Port: Copenhagen
Country: Denmark
Post by nieamm on May 28, 2019 14:11:04 GMT
Hi Ricardo Don't know if it's still an issue, but I have had the same issues replacing the relays on my J57(2012 #73) But my dealer(worldclass I must say) sourced them from Jeanneau, I have attached an image of the invoice showing the Jeanneau partnumnber, so any Jeanneau dealer should be able to order them for you. BR Niels Can't get the picture in here (now I can thanks MalcomP) www.23hq.com/Jy57/photo/55901277/original
Post by MalcolmP on May 28, 2019 17:53:01 GMT
