Post by billy on Jan 3, 2019 23:52:39 GMT
Hi again I’m still considering SO32i lift keel. For our local travel-lift/trailer I need to check the max width of the Bilge Keels. Would appreciate if anyone has access to an out of water SO32i lift keel to confirm this measurement please? Thankyou
Post by mikebz on Jan 7, 2019 11:42:33 GMT
Hi Billy, If I'd seen your post before I went to the boatyard yesterday I could have measured ours (which is a 32 not a 32i - from the pics I've seen on the web the keel configuration looks the same).
How quickly do you need the measurement?
Post by billy on Jan 7, 2019 12:20:32 GMT
Hi Mike, It would be great if I had the measurement in the next few weeks, before the end of Jan would be ideal. The one I'm looking at is currently afloat. Would very much appreciate this if you are back at the yard before then. Thankyou
Post by mikebz on Jan 7, 2019 12:45:06 GMT
OK no problem I can do that. Just to be clear, by "Max width of the bilge keels" do you mean the maximum distance athwartships between the outside of the port bilge keel and the outside of the starboard bilge keel (measured at the bottom of the keels), or the maximum width of each individual bilge keel (measured at the bottom of the keel)?
Post by billy on Jan 7, 2019 12:53:05 GMT
Thanks Mike, Exactly, the max width athwartships between the outside of the port bilge and outside of the starboard bilge keel. Approximately will be ok! (My local hoist-trailer has limited workable width between its inside wheels) Regards
Post by mikebz on Jan 7, 2019 14:01:15 GMT
Understood. I'll have it for you before the end of next weekend.
Post by mikebz on Jan 11, 2019 23:30:28 GMT
Difficult to measure accurately with the keels sat on big blocks of wood, but it's a bit over 1m, pretty sure it's less than 1.1m.
Post by billy on Jan 11, 2019 23:58:39 GMT
Mike, That’s great. thankyou so much. I’ll let you know how i get on
Post by mikebz on Jan 12, 2019 21:52:17 GMT
Post by billy on Apr 28, 2019 23:36:45 GMT
We have found a very nice 2008 32i lift keel. Starting our new season very soon. Thanks for your help Mikebz
Post by mikebz on Apr 29, 2019 9:41:22 GMT
Excellent, enjoy!
