Post by rucanito on Dec 31, 2018 9:07:35 GMT
Hi all, I own a 2001 SO32.2 (J.FAUROUX design I think) and would thank if anybody could tell me the ORC rating to be applied. Thanks in advance
MC & HNY
Post by Damir on Dec 31, 2018 14:53:06 GMT
Post by rucanito on Dec 31, 2018 17:42:25 GMT
Thanks Damir,
Sorry for my poor knowledge, but, how should I get the rating from so much info?
Post by Damir on Jan 1, 2019 10:45:53 GMT
On the left side are type boats and you must find yours if is on the list.
Post by rucanito on Jan 1, 2019 11:04:35 GMT
OK. Thanks!
Post by MartyB on Jan 1, 2019 19:35:51 GMT
Their is also a search area at the top. You can start inputting the brand, or just model of the boat. It will reduce the numbers a lot. I can not input Jeanneau Arcadia or Jeanneau Sun fast 32 to get answers for either boat. But input JUST Arcadia or Sun fast 32 I come pith with an Arcadia, and multiple sf 32s. OR you.May also have to add 32I, MY case sundream 28, I get more options too. From this, you can get base rating in a variance based on different sail sizes with in class. Build weights etc. You can also see speeds you should be able to attain in a given wind speed and direction. Yes a lot to take in, but if you want to be as fast etc as you can, from a race stand point. Worth it. Or cruising, you have a BEST speed based on wind, so you can attempt to get to that speed. But being as a cruiser usually has another 500-1500 lbs on their boat vs a race rig, speed will be slower....
