Post by MalcolmP on Nov 16, 2018 17:40:26 GMT
The Sun Odyssey 319 has been chosen as the Best Cruising Monohull Under 40ft in the annual Sail Magazine awards www.sailmagazine.com/boats/best-boats-2019Jeanneau Sun Odyssey 319
Good things come in small packages. Jeanneau’s new entry-level design is the Sun Odyssey 319, and she’s small but mighty. The French builder wanted to re-enter the small boat market, and the 319 joins two other models in the 30ft Sun Odyssey range. This way, Jeanneau has a boat for new sailors with families as well as old salts wanting to downsize.
It’s easy to build a large boat, but real thought must be put into a compact model. Available with two enclosed cabins and a full head, the 319 offers amenities similar to those of her larger sisters. Light pours in via the coachroof and hull portlights, and the ample headroom increases the sense of space. There’s a two-burner stove, refrigeration and a fold-out table that will seat six for dinner. The master stateroom is a V-berth forward with divided double doors. With these doors open, there’s a perception of length and openness you don’t often find on vessels of this size.
The cockpit is large with more outside stowage options than most of the boat’s competitors. A single wheel, a rigid vang and an open transom that provides easy access to the water are standard. The side decks are nice and wide with toerails outboard, and there are study handrails atop the cabintrunk to make going forward a snap.
