Free Revolut Card
Mar 1, 2018 10:35:00 GMT
Post by alenka on Mar 1, 2018 10:35:00 GMT
I have mentioned Revolut in a number of threads about money exchange, ATM's, etc.
Basically, it is a card which you load via a secure App on your smart phone and, using the same App, you can convert the funds into any of the major currencies at a time of your choosing and at the bank rate. If you keep to a low'ish number of transactions there are no charges. Equally you can send money to an overseas account at a very small charge, typically in my experience €1,200 costs about €10 which is much cheaper than any other system I have used especially as you are using the best exchange rate on the day.
I have found the card to be far more reliable than my normal Debit Card for taking money out of an ATM - It has never be rejected. Best of all as you pull the money from the machine a text message comes up on your phone to alert you to the fact of a withdrawal, so you are instantly aware of any misuse. Again a number of withdrawals per month are free then there is a minimal admin charge thereafter. You can also put the account to sleep between transactions which means it is even more secure. Another feature which my crew like is a 'Split the Bill' function that is easier to use (apparently) than it might sound.
Revolut used to make a charge for issuing the initial card but from now until the 9th March cards are Free to new customers so setting up an account costs nothing. Details are no doubt online but if you need a referral drop me a PM.
I have no connection with Revolut. I bring it to your attention purely because it works well for the cruising sailor.
