Post by someday on Aug 23, 2017 17:04:23 GMT
We have two cristec 60 battery chargers on out JEANNEAU 53. After installing a new genset, we noticed one charger works but the other does not. Confirmed power is going to the unit and our next step is to check the input ceramic fuses. Anyone have similar experience?
Post by Caxton on Aug 24, 2017 14:58:34 GMT
My Cristec charger on my 2007 SO39i started charging erratically so I replaced it with ProMariner which I am very happy with.
Post by so32foot on Aug 26, 2017 14:48:48 GMT
I have a 30 a Cristec loader in my Jeanneau. An internal fuse was melted, as well as the fuseholder. Easy to replace both.
Post by sleighride on Aug 31, 2017 15:07:25 GMT
My Crisrec charger died three years ago and I replaced it with a KISE smart charger that can handle three battery banks. It has worked very well for me, and I have the 60 amp model with four Trojan AGMs. The four batteries are group 31s, 100 AH each. Cost was $499 US for the charger.
Post by skylot on Dec 17, 2017 9:54:25 GMT
I have got the same problem with my Cristec CPS3. All the fuses are OK, 220V loaded, but there is no any output voltage and indicators lights off. Does anybody fix this fault?
Post by MalcolmP on Dec 17, 2017 11:55:18 GMT
Worth contacting the factory, esp if in Europe. They sorted out an issue very quickly for me a few years ago and speak English, if your French is limited. www.cristec.fr/english/
Post by so32foot on Dec 17, 2017 13:37:36 GMT
Measure first of all if 220 V AC is coming in, before the fuse and after it. If yes, is there coming appr. 15 volt out of the DC rectifier. If not, the rectifier is damaged. That is what happens mostly. Check than the diodes and condensators of the rectifier. That's the easy part, if this works it becomes more complicated and if you are not an electronic engineer it will be difficult to find the reason. In the Netherlands there are Repair Café's where they repair free of charge. May be there is one in your country. See repaircafe.org/en/
Post by skylot on Dec 17, 2017 14:41:31 GMT
Thank you for quick reply mates! Yes, there is 220V before and after ceramic fuses. Because I did not find any reset button on the charger block I`m going to take off boat charger unit to test that DC rectifier for faulty diode bridge and capacitors. I will inform you about the progress of this common problem of CSP3 repair.
Post by stefanw on Dec 18, 2017 4:56:48 GMT
I have the circuit diagram for the cps720 if that is of any use to anyone
Post by skylot on Dec 19, 2017 8:00:28 GMT
I have the circuit diagram for the cps720 if that is of any use to anyone Dear, Stefan could you send to me circuit diagram for the cps720? I think input circuit scheme will be very close to CPS3 circuit.
Post by terjegj on Mar 20, 2019 21:55:42 GMT
I have got the same problem with my Cristec CPS3. All the fuses are OK, 220V loaded, but there is no any output voltage and indicators lights off. Does anybody fix this fault? Hello, I have same problem. Do you get fixed the problem ?
Mike
Jeanneau Model: SO 380 Lift-keel
Yacht Name: Sea Otter
Home Port: Cruising
Country: Portugal
Post by Mike on Mar 31, 2019 9:01:15 GMT
Mike
Home Port: Cruising
Country: Portugal
Post by Mike on Mar 31, 2019 9:21:14 GMT
Hi, When we returned to our boat this year we switched on the battery charger on the main switch board, within a few hours a bad smell developed, we discovered two of our five AGM's had cooked.They were isolated by an electrician, which left us with three connected. We have monitored our system and found the outer case of our Cristec CPS3 charger to be getting hot. My question is "can any one tell me how hot/warm theirs is getting ?" Ours when on boost ours gets very hot, switch off SW1 and the case cools to warm.
Also it recommends in my manual to get the charger inspected every 5 years by a Cristec approved engineer. Has any one had this done? if so, were there any problems?
Post by rc sail on Mar 31, 2019 20:34:06 GMT
I share your frustration as my Cristec charger stayed in boost mode toasting 4 of my 7 batteries last summer. I did discuss this and a posting in these pages previously. I had no trust for the Cristec charger after this episode and it was replaced. There have been other postings on this charger and a recommendation is to disable, turn off, the boost function on the charger.
Post by NZL50505 on Apr 1, 2019 1:05:42 GMT
My Cristec also died last year and after hearing dubious reports decided to replace with Victron which I've had before. Superb products.
Post by rene460 on Apr 1, 2019 22:41:13 GMT
Hi Mike, good to see you back on the boat after your big trip.
A bit sad about the batteries, sounds like a new charger is in order, cooking batteries gets expensive as well as annoying. Turning off the boost is only a “get you home” solution until you can get a new charger as it means you don’t quite get the batteries fully charged. But it should save cooking more batteries in the short term.
Ours in not a Cristec. While it gets warm, I would not call it hot, but obviously very subjective terms. I have not tried to measure the temperature. Next time I am on the boat I will get out the infrared thermometer, always good for quick comparative readings. I would prefer to see it a little cooler, but I have always put the warmth down to minimal ventilation in the charger compartment. Not easy to increase the air flow around there.
Might be worth following up Malcolm’s suggestion earlier in this thread (17 Dec 2017) to see if there is an “approved engineer” in your area, to see if it can be repaired.
