Post by colinhession on May 12, 2017 16:14:50 GMT
If anyone is looking to replace sliding window rubbers for Merry Fisher 655 (or similar?), can recommend:
www.lbhproducts.com (01223 655428)
click: Marine EPDM rubber with flocked coating fits in channels for sliding glass or Perspex
click: product code WF32 (not WF25)
then order it by the metre, quite easy to fit, once you've worked out how to slide out window!
Post by wfa on Aug 16, 2019 16:34:26 GMT
I looked for the same seals - here is a more recent supplier
soncek
Jeanneau Model: Merry Fisher 605 series 1
Home Port: Runke - Medulin
Country: Croatia
Post by soncek on May 13, 2023 20:49:34 GMT
None of the Links in this thread are leading to active web pages. It seems that sellers mentioned in the two post in this thread are out off business.
Would anybody have a link to an active seller of EPDM rubber with a flocked coating for Merry Fisher sliding windows?
I measured the flocked rubber slider on my MF 605 2016 Series 1 edition and the dimensions of the rubber were: cca 17-18mm wide and 12 mm high. The Rubber slider has also a very specific shape. I tried to search the web but I do not find any similar size/shape available for purchase.
Help is highly appreciated.
Also, it would be great to learn how to "slide out" the window from the aluminum window frame.
Post by stuwright on May 29, 2023 18:48:39 GMT
Also, it would be great to learn how to "slide out" the window from the aluminum window frame. I’d be interested in this because the ones I’ve previous bought from the dealer were standard rubber which only lasted a few years before starting to crack. It made me wonder if the replacement seals are as good as the ones used at the factory.
mf755wahoo
Jeanneau Model: Merry Fisher 755
Yacht Name: Wahoo
Home Port: Falmouth
Post by mf755wahoo on Nov 13, 2023 13:23:56 GMT
Afternoon - after the same info re new window seals for our MF 755. Ours are cracked and also growing a whole new biosphere! Thanks
