Post by MalcolmP on May 3, 2017 23:17:45 GMT
Post by ianpowolny on May 4, 2017 13:57:17 GMT
Guys,
Thanks to Malcolm for his help with this. Emma from Grassi Bateaux of La Rochelle found the parts and will get them to me early next week.
For anyone with a similar problem the large nipple (pt. no. 990515) on the end of muffler is a separate part.
This muffler is used on the 75 & 55 hp engines but sure which model boats.
I'll write a longer report next week on the job. Can't believe how much disassembly is required.
Ian
Post by vasko on May 4, 2017 18:24:08 GMT
Ian why you are changing the muffer ? \what are the signs that a muffer need changing ?
Post by ianpowolny on May 4, 2017 21:01:43 GMT
Vasko,
When we went back in to the water and started the engine we didn't have any exhaust water from engine stern exhaust; then noticed water coming in to the bilges from the engine compartment.
On expection found the exhaust muffler had holes in it.
Ian
Post by Tafika II on May 4, 2017 21:09:56 GMT
We had the same condition with a wet muffler hole (thin wall rototmolded area), but some of the leak was coming from the large threaded hose adaptor with the "O" ring seal. The original wet muffler had a molded in thread. The new one had a brass threaded insert. We replaced the entire wet muffler, large threaded fitting & the "O" ring. No leaks & all is well. The mechanic of removing the wet muffler is not complicated, but it does require removing the companionway stairs and frame work. I think the job took about 2-3 hours total to remove and reinstall.
Post by vasko on May 5, 2017 5:37:00 GMT
Vasko, When we went back in to the water and started the engine we didn't have any exhaust water from engine stern exhaust; then noticed water coming in to the bilges from the engine compartment. On expection found the exhaust muffler had holes in it. Ian Thanks Ian
Post by ianpowolny on May 5, 2017 7:57:37 GMT
Vasko,
One thing I forgot to mention is that there were a lot of exhaust fumes from the leak. If this happens to you get the hatches opened and vent the saloon.
All, has anyone fitted a flow sensor to the exhaust system? If so how did you do it and which type did you buy? My mechanic is suggesting this might be a good modification to make.
Thanks Ian
Post by vasko on May 5, 2017 10:40:32 GMT
My boat is a bit more noisy from the exhaust then I want.. and was curious can the muffer be a issue.. hence the question...
Post by ianpowolny on May 16, 2017 6:37:45 GMT
The replacement exhaust muffler arrived from Jeanneau via Grassi Bateaux, La Rochelle. As you can see the new muffler has a brass insert and we found it was about 15mm longer. Note that the inlet nipple does not come as part of the kit so must be ordered separately. On our 45DS we we had to remove the companion way all the way back to the sole plate support beam in front of the engine. Finding the retaining screws behind the annenuation material was not that easy. Thanks to Rum Johnson of tecno-nautica.com/en/home/ for help with the engine service, finding the problem and installing the muffler.
3buoys
Post by 3buoys on May 16, 2017 11:27:50 GMT
The replacement exhaust muffler arrived from Jeanneau via Grassi Bateaux, La Rochelle. As you can see the new muffler has a brass insert and we found it was about 15mm longer. Note that the inlet nipple does not come as part of the kit so must be ordered separately. On our 45DS we we had to remove the companion way all the way back to the sole plate support beam in front of the engine. Finding the retaining screws behind the annenuation material was not that easy. Thanks to Rum Johnson of tecno-nautica.com/en/home/ for help with the engine service, finding the problem and installing the muffler. Hi Ian, so your all up and running now. I bet your glad that's all over with so well done . See you in about two weeks. Regards Paul
Janissah
Sail now....Work later
Jeanneau Model: Sun Odyssey 45
Yacht Name: Janissah
Home Port: Valletta
Country: Malta
Post by Janissah on Sept 26, 2017 8:43:26 GMT
Ian
The same thing happened to me, my exhaust muffler went. The mechanic just took it out and it was no end of trouble to do so, as its under the engine mount.
What the hell was Jeanneau thinking to install it under there??
Mine was the stainless steel one and it just rotted.
Your new one seems to be plastic. Is that right? Any idea how much it costs
Thanks Mario
Post by ianpowolny on Sept 26, 2017 16:04:42 GMT
Hi Mario,
The muffler plus the nipple was €227.88 plus €75.70 for shipping La Rochelle to Portimao, Portugal. I was very impressed by the quality of service we received from Emma at Grassi Bateaux - emma@grassibateaux.com. Would definitely use them again.
Our muffler was plastic so I can't say if it's a direct replacement for your stainless steel model. I suggest you contact Emma with the dimensions of the s/s version and see how it matches with the plastic one.
I did have to re-drill the forward holding bolt hole. All is good now though.
Is you 45DS 2008?
Ian
Post by Spritz on Sept 30, 2017 11:46:04 GMT
On my 2011 42DS is plastic too. Unfortunately is in the same horrible place of yours, practically under the engine.....
Janissah
Home Port: Valletta
Country: Malta
Post by Janissah on Oct 2, 2017 12:50:50 GMT
Mine is stainless steel, will post a picture in a minute
Not having much luck in sourcing it, Emma did reply but hasn't come back with anything yet..
As for jeanneau....they try their best
Mario
Janissah
Home Port: Valletta
Country: Malta
Post by Janissah on Oct 2, 2017 12:51:33 GMT
Anyone know who manufactures the plastic ones?
Post by ianpowolny on Oct 3, 2017 11:28:08 GMT
Here's Emma's number: T. +33 (0)5.46.45.40.06. She speaks good English.
The plastic muffler is a Jeanneau part which I got through Emma direct from the factory at La Rochelle.
Ian
Janissah
Home Port: Valletta
Country: Malta
Post by Janissah on Oct 4, 2017 11:23:10 GMT
Ian
Would you have the part numbers handy?
Thanks
Mario
Post by ianpowolny on Oct 4, 2017 15:40:19 GMT
Mario,
Take them from the photos at the top of this thread.
Don't forget the nipple is a separate part and check they include the 'o' ring.
Ian
Janissah
Home Port: Valletta
Country: Malta
Post by Janissah on Oct 4, 2017 19:15:18 GMT
Mario, Take them from the photos at the top of this thread. Don't forget the nipple is a separate part and check they include the 'o' ring. Ian Thanks my good friend
Post by andreshs1 on Mar 7, 2019 8:40:09 GMT
hello guys
do you know if this part will fit a 43DS?
the local Jeanneau service is trying to push me the old metal one and I tried emailing Emma but I got no response
any help will be appreciated
cheers
Post by tsenator on May 1, 2019 21:07:39 GMT
andreshs1,
I would love to know the answer to that question too ! With all these boats having issues with the Stainless Steel mufflers from that era you would think Jeanneau or someone would come up with a better alternative like these plastic/fiberglass ones .
Tom
Post by windward54 on May 4, 2019 14:07:36 GMT
I was told by Jeanneau that the plastic mufflers won’t fit, and can’t be used as a replacement for the stainless steel muffler.
Post by alex1949 on May 4, 2019 14:26:28 GMT
Hi all, Why won't we all ask mother Jeanneau clear and sound : Why do we have to replace 2008 made mufflers so soon !!!! To my humble opinion it is a real shame no matter what was the reason for that.
Post by ianpowolny on May 4, 2019 15:18:41 GMT
tel:+33546454006
I think this is the number for Grassi Bateux
Post by andreshs1 on May 5, 2019 0:35:16 GMT
