Post by abgreenbank on Feb 4, 2017 11:08:17 GMT
A few pictures of how to repair voids in gelcoat antiskid. Circle is a void which is more visble in strong sun when the trapped air expands. apply mold release wax remove gelcoat ready to fill with resin and mat filled with resin and mat remove excess laminate cut antiskid mold to size, jeanneau sells A4 sheets. make sure mold is aligned and interlocked correctly make a hinge so the mold folds back but maintains alignment. apply gelcoat paste, lots of it after cleaning the laminate with acetone, dont touch the mold realease! firmly interlock the mold and apply lots of masking tape remove when set, the mold release stops the gelcoat sticking to the surrounding antiskid. light sanding to finish regards ab
Post by MalcolmP on Feb 4, 2017 12:16:42 GMT
Excellent AB - I would like to add to Hints and Tips as a permanent article? M
Post by abgreenbank on Feb 4, 2017 13:00:41 GMT
Hi Malcom I have no problems with that, I also have a short video of the mold being removed but haven't quite worked out how to upload. i will also do a part 2 which is the replacement of a whole anti skid panel, the finished job is the bright white panel with pencil marks next to the repair site in the photos above, but give me time.
regards
alistair
Post by MalcolmP on Feb 4, 2017 15:34:58 GMT
Excellent. If the video is already on Youtube there is a simple link on the forum - click the clapperboard
Look forward to seeing remained of project in due course. M
