Post by c1gmlm on Aug 1, 2006 18:55:31 GMT
I have a yanmar 3GM and would like to add hot water heat while under way. Right now I have only hot water when at dock hooked to 110v. Is there an attachment that's available?
Thanks Mike c1gmlm@aol.com
Post by notorious7004 on Aug 1, 2006 20:31:19 GMT
You should be able to heat your water using the engine; that´s the only way I do it in my Sun Legende since I do not have 110 volt system. By the way, it works excellent!
Post by MalcolmP on Aug 2, 2006 17:02:23 GMT
caledonia
Jeanneau Model: Sun Odyssey 36.2
Yacht Name: Caledonia, Flower of Scotland
Home Port: Amble, Northumberland but currently cruising the Med.
Post by caledonia on Aug 12, 2006 22:18:27 GMT
I agree. I have a 3GM30F in my SO 36.2 and it heats the domestic hot water, as does the 240v mains electric when I'm hooked up in the marina.
Glen
