Post by clydecali on Apr 26, 2016 18:06:05 GMT
I have recently purchased an Attalia and require a replacement plywood panel for inside the forward facing window in the saloon, does anyone know where such a part can be sourced as Jeanneau do not stock these any longer?
Clydecali
Post by MartyB on Apr 28, 2016 12:55:51 GMT
Depending upon where you live, there is more than likely a lumber yard that stocks teak plywood locally. Find a piece that looks like what you have, same thickness and start cutting, sanding, installing etc.....
