Post by peters on Jan 20, 2006 17:50:46 GMT
Hans Check the pump literature. I mave a PAR pump that has a pressure adjusting screw on the pressure switch.
keebs
Post by keebs on Jan 23, 2006 15:27:29 GMT
Hi Hans The pressure relief valves should be exercised regulary to prevent build up on valve, I'm sure most people do not do this. Try exercising valve for a few seconds may clear build up or residue and solve your preblem. Best of luck.
Post by hansenkarinbos on May 22, 2006 15:21:26 GMT
I checked the relief valve and cleared it from salt depostits, now its working ok. Thanks
