Post by abgreenbank on Jan 18, 2016 15:13:28 GMT
for those it may affect, I believe there is a fairly new recall campaign from Jeanneau about faulty relay in SO349 swing keel.
Recall Campaign n° 16507 « Relay SO3MA – code 16507
suggest you contact
N.VRIGNAUD@jeanneau.fr
regards
ab
Post by jcnyb on Jan 20, 2016 17:30:43 GMT
Hi, You are quite correct there is a campaign on this currently whereby they i.d. an instance where the relay could develop a fault causing it to stick on. The best port of call is going to be your local dealer (they should have contacted you already) - they have been given an inspection routine to check if the relay in any specific boat is faulty. We have done one and found its fine, I do not get the impression that it is a major issue. Anyone needs more info or help with this then feel free to PM me.
amj
Post by amj on Jan 21, 2016 13:57:18 GMT
Just had mine checked out, happy to report all OK, check involves a current leakage test with a multimeter between the solenoid ground and the motor body, which should be less than 3v.
