Post by vasko on Jul 24, 2015 23:36:15 GMT
Post by On y va on Jul 25, 2015 11:25:07 GMT
Yes, I have a 16 KG Kobra. It is very good. Never fails to set. Very cheap too, as I get 35% trade discount, so I only paid 106 euros.
Post by vasko on Jul 25, 2015 12:54:23 GMT
very nice to hear I have 16kg Bruce currently didn't had issues so far, but thinking to get a 16kg Kobra 2 ... Just I'm still not sure am I able to put 16kg Kobra on the place of 16kg Bruce or I will need to go down to 12kg Kobra to be able to fit it at the same bow roller on my 34 foot Sun Liberty
Post by pbunning on Jul 31, 2015 21:18:57 GMT
I had a 16kg Kobra 2 on my SO33ip. Always set well first time. Only problem is that it interfered with removal bowsprit pole for my cruising chute. I started keeping it in the anchor locker. Since I found it difficult to handle, I have just replaced with a 12kg Rocna Vulcan.
Had a Bruce on my last boat SO34.2, was not entirely happy with it - didn't always set first time.
Post by vasko on Aug 1, 2015 6:39:41 GMT
I had a 16kg Kobra 2 on my SO33ip. Always set well first time. Only problem is that it interfered with removal bowsprit pole for my cruising chute. I started keeping it in the anchor locker. Since I found it difficult to handle, I have just replaced with a 12kg Rocna Vulcan. Had a Bruce on my last boat SO34.2, was not entirely happy with it - didn't always set first time. Was the Kobra too big to fit ? I currently have 16kg bruce and I'm trying to determin if the 16kg Kobra will fit...
Post by vasko on Aug 4, 2015 20:12:14 GMT
Finally decided on Kobra 2 14kg for my 34 feet crab pod - hope it is not too small and not too big to fit... ordered it from www.segelladen.de/ £102 inc. the shipping to south of France...
Post by vasko on Aug 19, 2015 13:23:07 GMT
installed 14kg Kobra 2 on my 34 foot Sun Liberty - all seems good - sets well first time and hold well in 35kt wind so far - the only thing that I can say comparing with my previous original licensed/patented Bruce 16kg is that the Bruce was a lot better with shorter chain e.g. was setting and holding with 2x - 3x depth chain - the Kobra II seems to require 4x - 6x for perfect setting .. and the short swinging circle is useful in crowded anchorage...
BTW: if someone need a original extremely well build Bruce 16kg ( in Belgium) all stamped on the anchor I can sell mine...
Post by MartyB on Aug 20, 2015 0:39:03 GMT
You may want to keep that bruce for situations you just described. As the Bruce WAS designed to hold oil pump platforms with 2 or 3-1 purchase. Hence why you probably feel it holds and sets better with less rode.
My 02......
Post by vasko on Aug 20, 2015 6:48:41 GMT
Bruce is good and looks better on the bow , holds well till around 20kt after that it starts to drag very slowly about 1m and hour , but still drags, Kobra 2 once set looks like can hold forever with the slight problem with the need of 1:4-1:6 (depth:chain length) chain as a minimum... - which in 12m-15m depth in busy anchorage gives quite a big swing - but it looks all new anchor types suffer from this e.g. I will need to live with it .... and Yes I most likely will keep my Bruce as it looks very difficult to find a original/patented and proper build quality one
