Post by vasko on Oct 27, 2015 17:12:53 GMT
Post by vasko on Mar 30, 2016 19:05:17 GMT
I'm heading tomorrow to France to get my boat out and do the year maintenance including new antifouling the decision about the mixture is made hull ---- Blacks/Hempel - Ocean Performer with added per every 2.5l : 10ml Ivermectin 1% , Panacur - 100g, 24 x 1000mg Ospamox, 100g Tetracycline. prop & shaft --- SeaJet Triple Pack with the same additional gradients as for the hull proportionally - I'm hopping to get 2 years without another need for anifouiling , but will know later in the year how the mixture performs..
Post by vasko on Aug 5, 2016 12:44:18 GMT
after 5 months in the water I can safely confirm that the mixture of: 10ml Ivermectin 1% , Panacur - 100g, 24 x 1000mg Ospamox, 100g Tetracycline( for cows from veterinary shop). per every 2.5L antifuoiling has done a EXCELLENT job! - no barnacles whatsoever - will use it in next antifouiling also.
unfortunately I cannot report any good results for Seajet Triple Pack - same result as no antifouiling...
Post by MalcolmP on Aug 5, 2016 15:57:54 GMT
unfortunately I cannot report any good results for Seajet Triple Pack - same result as no antifouiling... Just hauled out after 3 months - I had also carefully degreased, cleaned and applied the seajet triple pack - which takes time... result quite a lot had fallen off on the prop, - but not on the shaft, rope cutter or bow thruster props etc. No barnacles at all BUT did not have growth anywhere else either (I have copper coat on hull) but normally get a few critters on places like top of rudder, underkeel so guess this was due more to the waters we have been in - mostly northern Spain salt but also in fresh water basin for a few weeks then a fresh water river for a week. As others have said Propspeed is the very best for props, but it is just so expensive that I thought I would try the Seajet - looks like I will be saving up for more Propspeed for next season unless Vasko can work out a DIY version ?
