Post by adrianpetts on Jan 29, 2015 17:14:07 GMT
Does anyone know the type, and make, of the fuel tank sender unit fitted to Jeanneau Sun Odyssey 40? Mine seems to have stopped working. Any recomendations for a good sealant to remake any joints to the pvc tank? Boat based SW UK.
Post by dnickj on Feb 3, 2015 13:24:48 GMT
hi the sender is a VDO unit but when I removed mine from the tank is found a connection wire had broken so just soldered a new piece in and all fine - just resealed it back onto the tank with silicone
Post by touchngo on Feb 3, 2015 19:53:06 GMT
VDO for mine also. Mine had been working but not properly. IE. Full tank showed as above full, and a quarter tank showed around 3/4's etc... I simply spent a morning cleaning it thoroughly (and gently). Works like a charm now.
It isn't a particularly complicated piece of kit. As far as sealing it down, it already has a gasket (or should have), so no need for silicon or the like (just be careful not to destroy the gasket when you remove it from the tank).
Hope this helps.
PT
