Post by chuckr on Dec 21, 2014 13:39:29 GMT
the vinyl that covers the walls on the forward berth have come lose and fallen. glued one back but is not holding well so i thought i would just replace them. unfortuantely jeanneau na said they could not help me find some. any ideas on where i can it? we are in tunisia and headed to italy, albania, greece and turkey next year. thanks
Post by sailbleu on Dec 21, 2014 16:13:20 GMT
Chuck ,
one of the wonders of this world , our world I mean , is Sikaflex 291i . Use a putty-knife to spread it out in a thin layer , bash the vinyl in a bit and that will be one chore less on your to do list. Regards
Post by vasko on Dec 22, 2014 11:13:28 GMT
I had quite a bit of problems with the wall's vinyl covers - all my walls are covered with vinyl... and after some try with different adhesive - including specialized marine adhesive spray - all options has failed under the Spanish strong sun except : 1. Sikaflex - as mentioned - but to expensive and not very easy to manage on a large surfaces ( depends how much of the vinyl is un-glued) 2. A Bulgarian made PCP glue which cost about £3/kg - but no idea from where you can buy it except in Bulgaria .. it states Dupont & Bayer on the box.. e.g. should have analog but I hasn't found it yet and have sourced the glue for my boat from Bulgaria .. markita.net/sites/default/files/imagecache/product_full/produkti/lepilo_proma_650gr.jpgmarkita.net/lepilo-proma-0650.html
ubuysa
Post by ubuysa on Dec 22, 2014 14:05:35 GMT
You can buy foam-backed headlining vinyl from Kayospruce in the UK. It's expensive though.....
