manlyp
Post by manlyp on Aug 1, 2014 14:51:58 GMT
Has anyone replaced the morse control on a Jeanneau 45.2? Mine is very worn (sloppy) and needs replacing. I've had it apart but I cannot get the control unit out of the hole with the es attached and there is no access from behind. The Teleflex TX172103 looks like the replacement part but unless it can be fitted from outside with cables attached it won't work! Any ideas please? I read somewhere that the Teleflex CH2100 (which looks the same as the TX172103) can be bought with an attahment plate and am wondering if this is relevant and whether you can still buy it.
