Post by johnandpauline on Apr 23, 2014 22:34:24 GMT
Attached photo is whats left of the hose tail on my 40.3. Yacht was purchased 2006 & is fitted with a Yanmar 4JH engine. If this wasnt discovered during routine maintenance the results could have been disastrous.
Post by sailbleu on Apr 24, 2014 5:21:36 GMT
Good thing you showed this to usJohn. Absolutely to check by all 40.3 owners . But do you have any other ' consumed ' parts , because that could prove something else is going on no ? Not sure about Yanmar , but is that also an isolated engine , meaning no negative on the engine ?
Post by debenbar on Apr 25, 2014 18:24:35 GMT
The tail on the engine inlet seacock of the 3JH4E in my 39DS of 2007 vintage snapped off during maintenance. I have now replaced all the seacocks below the waterline and would recommend any owner to do the same for peace of mind.
ChrisH
Out West, or in the office.
Jeanneau Model: 342
Country: Scotland
Post by ChrisH on Apr 25, 2014 23:09:08 GMT
I've previously posted here with pics in the hints & tips section of the hose tail from a1999 34.2 in a similar condition. Unfortunately Jeanneau like most if not all other manufacturers are using cr4p brass fittings . This is the EU directive that sea clocks and fittings should last 5 years!!!! So everyone stopped using more expensive bronze or DZR which will last a long time to cheap brass cr4p which will last 5years and 1 day....... If you're lucky!
