Post by mikebz on Apr 22, 2014 14:00:26 GMT
Our SO32 has a mystery pushbutton switch in line with the starter & house master switches - can anyone tell me what it's for? It's a single pole push-to-make/release-to-break. Attachment DeletedMike
Post by Don Reaves on Apr 22, 2014 20:29:19 GMT
I have a similar switch on my SO35 that provides power to the windlass. In my case, it's a toggle, though.
Post by mikebz on Apr 23, 2014 14:34:38 GMT
Thanks Don, it's definitely not that in our case.
Post by Don Reaves on Apr 23, 2014 21:17:59 GMT
If you figure it out, perhaps by tracing the wires, please let us know.
Post by mikebz on Apr 23, 2014 21:24:30 GMT
Will do.
Post by alenka on Apr 24, 2014 8:11:02 GMT
Bow truster? Electric winch?
Post by mikebz on Apr 24, 2014 11:49:28 GMT
Boat has never been fitted with bowthruster or electric winch, and it's a very small switch with small diameter wires. It's a pushbutton switch which only makes while you have your finger on the button so I assume it must be some sort of reset. The wires disappear into the loom but where they go then is anyone's guess.
Post by shiook on Apr 24, 2014 12:41:18 GMT
It might be your inverter. "Push to activate"
Post by danydv on Apr 24, 2014 13:37:08 GMT
Good afternoon,
on our SO33i we also have a toggle switch to activate the sensor of the fuel meter. When not pushed the fuel meter is not activated. Maybe........ Have a look.
Greetings,
Dany
Post by mikebz on Apr 24, 2014 14:08:47 GMT
Thanks for all the suggestions, I appreciate the ideas.
I'm 99% sure there is no inverter (unless it's well hidden and wasn't mentioned in the inventory).
It's not a toggle switch, it is only 'made' while you hold it down. It's down in the aft cabin alongside the master switches, so it can't be used to control anything that you might want from the cockpit (or at least if it does then it's in a daft place). The fuel gauge appears to work without having pressed this switch.
Post by alenka on Apr 24, 2014 14:40:48 GMT
It really does sound like an RCD or thermal cut out type switch. They seem to fit them where there is a direct connection to a seperate battery for some heavy duty device like windlass or winches.
I did look at a boat some years ago that had all the switches left in place associated with a Genset but the owner had taken it with him onto his new boat and they were no longer in use.
Is there no way you can contact the previous owner?
Post by alenka on Apr 24, 2014 14:42:47 GMT
Come to think of it my previous boat had something similar to kill the engine from below decks. Try pressing it with the engine running and see if it stops!
Post by mikebz on Apr 24, 2014 22:28:45 GMT
I'll try that! Presumably it would require an electrically controlled decompression mechanism.
Post by alenka on Apr 25, 2014 8:12:03 GMT
I guess so. In 8 years we never used this feature once on our last boat but obvioulsy someone thought it would be useful.
Post by On y va on Apr 25, 2014 16:46:11 GMT
Do you have a key to start your engine? Or a push button?
Some people (like me) have an extra starter button installed, as the keyswitch on your engine panel in the cockpit is a "weak link" in the whole starting system.
Post by mikebz on Apr 25, 2014 22:27:54 GMT
A push button - thanks, something else to try!
Post by kenlewis40 on Apr 26, 2014 6:06:40 GMT
It could be to call the butler !!! or maid!!!!
Post by mikebz on Apr 26, 2014 15:08:56 GMT
It is ideally positioned to call for breakfast from the aft bunk.
Post by renegade27 on Apr 26, 2014 15:42:11 GMT
My 2004 SO35 has the same push/pull switch. I need to pull it out to shut down the instruments completely, and push in to activate the "Instrument" toggle on the circuit board. Your mileage may vary!
Post by mikebz on Apr 27, 2014 17:48:37 GMT
Well it's not engine kill or start. I've only tried pushing it (it springs back when released) not pulling it out - will try that next time I'm on board. Some of the instruments are always on when the house master switch is on, so it would be useful if this was a way of shutting them down.
Post by mikebz on May 5, 2014 17:02:16 GMT
Congratulations to renegade27. It is actually a toggle switch, I just wasn't pushing it hard enough to toggle it! It switches instruments on/off so now I can have house batteries on when moored without wasting juice on instruments. Thanks to all for your suggestions!
Post by corksailor on May 5, 2014 21:10:47 GMT
I think you will find that the switch shuts down the the st 60 instruments read out at the helm It does on mine Possibly to save battery power check your readouts and then push it They wil go blank Sometimes when you switch off the batteries the instruments are still reading so this eliminates the power drain
Post by mikebz on May 6, 2014 7:18:00 GMT
Thanks corksailor, that is exactly what it does (see my last post).
