Post by philip on May 17, 2005 10:24:13 GMT
As anyone had this problem. For some reason my water heater when used seems to empty a small bit of water into the sump. I have turned down the temp to 55 with no effect. Thanks Andrew
Post by MalcolmP on May 17, 2005 18:14:26 GMT
Unfortunately leaks from the calorifier pressure relief valve have been noted on several models Your dealer should be aware of this problem and be able to supply a replacement pressure relief valve but it does seem there is a ongoing problem with the quality of these valves (if I recollect correctly they are Cleghorn Waring ones) Malcolm As anyone had this problem. For some reason my water heater when used seems to empty a small bit of water into the sump. I have turned down the temp to 55 with no effect. Thanks Andrew
