silem
wiring
Feb 27, 2012 7:02:19 GMT
Post by silem on Feb 27, 2012 7:02:19 GMT
anyone know the routing to run cable from the lower helm dash to the radar plinth on a prestige 32 (2004)
davidh
Prestige 32 Sundance
wiring
Feb 28, 2012 19:38:15 GMT
Post by davidh on Feb 28, 2012 19:38:15 GMT
Hi The radar is fitted to the tripod which slots into the handrail of the fly bridge and the two outer legs are screwed to the upper rear fly bridge mould. There is a inspection cover underneath the rear fly bridge seat back which folds down when converting into a rear upper sunbed. Unscrew the plastic circular cover and the wires coming from the radar tripod can be accessed here. These wires should travel over towards the upper starboard radio/stereo speaker. Remove the speaker cover and you can access these wires again. These wires travel down into the lower cabin inside the structural fly bridge support. The cover can be removed from this support from inside the lower cabin. From this point you should be able to work out how to take the wires to the lower helm position. I hope this helps.
David H.
