Post by paradox on Aug 25, 2010 17:47:22 GMT
we have a 2008 42DS sailboat. We do week long cruises in Long Island Sound. There are many gas/diesel docks available but we do not like to spend our time there - has anyone added additional diesel tanks to increase range?
Post by merwin on Oct 3, 2010 12:22:08 GMT
We have a 49 with 3 water tanks. We converted the starboard aft water tank into a second fuel tank. It is the same type tank as the port aft fuel tank. We added a fuel tank switch so we can direct the flow to the engine. It has worked well. With a water maker we can make water, but we can't make fuel.
Post by Zanshin on Oct 3, 2010 12:38:32 GMT
Did you get the Jeanneau kit or purchase just the tank? I am thinking of getting the system with the transfer pump for my 49DS.
Post by DUET on Oct 3, 2010 20:12:44 GMT
see :additional tankage." I just completed this conversion. Basically, there are two vaules: a return and supply for each tank. The generator will continue to gets its supply from the original diesel tank so using the new tank (formerly water) first is preferable. Jeanneau does not have a kit although I believe it will be offered on the 53.
Post by Tafika II on Dec 14, 2014 16:08:25 GMT
Paradox...did you ever make this conversion for more fuel? If so, what exactly did you do?
Post by chuckr on Dec 21, 2014 12:10:28 GMT
we added a 50 gallon tank under our rear berth of our ds40. it was custom built to fit the space and work was done by deltaville boat yard in deltaville va.
